Baffle question
The mufflers on Bertha are fishtails. As far as I know, there are no baffles made to slip into the end.
I'm going to HAVE to put the baffle here, or slide it into the slip on. Either way, its going to end up pretty close to this hole.
Received 4,361 Likes
The pic shows a pipe with a heat shield attached.
You can put baffels in fishtails. I did.
I just got some replacement baffels from Drag. I had to drill a hole in the pipes to put the bolt in but you can do it.
I put the hole just behind the bracket on the end of the fishtails.
You just reminded me that there is a (I think you call it) a lollypop mounted back by the mounting brackets. I wonder if I could remove that and put a baffle there?
Depending on where the hole is you might not have to drill one into the pipe to mount your baffles.
