Dunlop D404, on a softtail?
Received 4,361 Likes
Here is a tire size chart.
https://www.denniskirk.com/help_cent...sp#width_table
I am currently running a 140/90 Dunlop 491 elite 2. As far as I'm concerned it is a much better tire than the 402.
when I ran 402's I used to slip on the road paint and would wear out a rear tire at 8k.
The 491's don't slip on road paint and I have 7k miles on the rear tire with very little wear.
because 1/2 of the tire was rubbing on the lower belt guard.
Texas H/C,
Are you running them front and rear and how is the 491 in road snakes or seams?
Like Silver Ghost I run through a 402 every year and they were never that great on wet roads. Last year I tried a set of Metzlers and they work really well but are low profile plus I'm not sure they will wear anybetter than the 402s.
Thanks
D
Thanks
D
I'm not sure if the differance between the 130 and the 140 is worth the change but I know that I had to add a 1/8 in. spacer to my axel (don't know if the rim is bent or it is because of the tire width)
Texas H/C,
Thanks
D
Thanks
D
When I was first thinking about using them I found some cites that said the tire was supposed to last 16k. I'm not sure about that but I will find out.
