Dunlop D404, on a softtail?
Received 4,361 Likes
That's the other thing I wanted to know, I have no problem putting in a spacer for the 140/90, just wanted to know before hand, I realize you can only space out the rear pulley so far before you have to move the trany or space the trans sprocket. If it's only 1/8 or so, that should not be a big problem with alignment.
Like I said before this might not be because of the tire/spacer. The previous owner of the bike was caught in a sandwich and rebuilt the bike (by a dealership). I'm not positive they got it right. I think the rim might be a little off.
When you put your 140 on yours I would try it without the spacer first (you may not need it) and if you don't mind let me know how it worked out.
What is your secret?
So now that I know that 130 is the proper size, and 140 will fit with a spacer, I have a lot more tire options to choose from, I'm going to stay away from the 404's I can get some Continental CM1's or Metzeler's at a good price($133), and still way cheaper than the 402's.(180+tax)
I know I'm only going to get a year out of my tires, I'm just tired if paying over 200 bucks for a so,so tire that has Harley Davidson on the sidewall.
Thanks for the help guy's.
I don't know Texashillcountry; Maybe because I am 71 years old and don't ride very hard. LOL.
When I had my old Iron Head Sportster, I put on a set of Continental's, and they road way better than the Dunlops that I had been using. They stuck like glue and had very soft rubber. I loved them, but they wore out very quick. Dunlops are harder rubber, maybe do not stick as well, but do seem to last very well for me.
I do have a friend with a late model Fatboy, and he is only getting about 6 to 8 thousand miles on his Dunlops, but they are a special size tire that Dunlop seems to be having a problem with. Dunlop has given him at least one new tire.
It's not the money, but the tire, the 402's are very slippery for $200, I can't see a Metz or Cont being any worse. they may even be better, If the 402's were any good, I would gladly pay the price, I just don't think there a good value, seems like I'm paying for the Harley logo.
You have to remember what HD stands for---hundred dollars. It seems to me that as soon as they but their logo on something the price goes up by about that much.
Good luck on your tire hunt.
Regarding any tire issues, I spoke to the dealer about that after reading about it on the fourms a while back. They told me it was more of a mounting issue that was supposedly resolved. The tires were then cupping messing up the ride and causing a wobble. Sometimes it helps to verify tread direction.
Have you found any info?
I'm not sure if the differance between the 130 and the 140 is worth the change but I know that I had to add a 1/8 in. spacer to my axel (don't know if the rim is bent or it is because of the tire width)
because 1/2 of the tire was rubbing on the lower belt guard.
