want your opinions (swingarm upgrade)
Ok, so my flht moves around quite a bit in the corners, and of course I'm on a budget, so with that said, I'm either going replace the swing arm isolators and use a progressive arm or I'm going to buy cce spherical conversion kit, what would you guys do ? And how much work is that spherical kit ? Thanks
Contact them direct, I'm fairly certain they do. I bought a Trackula kit before I installed my later swingarm and modified the bushes to fit. What you need are later bushings to fit the newer swingarm with smaller ID bore, to take an early axle.
Yes, you'll be fine. I bought a new braided hose and ran it straight to the 'new' caliper from the MC (). Having connected it and topped up the fluid I pumped the pedal a few times with the bleed nipple open and fluid came straight out. That was a surprise, so I closed it, pressed the pedal and it was as firm as a rock. Never bled a brake so quickly and easily in my life! Hope yours does the same.
