Need help on 1990 fltcu tour glide
Old 04-28-2012, 10:52 PM
Gunslingertom's Avatar
Gunslingertom
Gunslingertom is offline
Originally Posted by veejay
Do any of you guys still have the old console parts? A friend is trying to fix his 1990 ultra classic, and would be interested in the circuit board on the console.
Are you talking about the CB controls? I have them. In fact I have the entire CB-intercom system minus the mics.
Old 04-29-2012, 08:31 AM
Schex's Avatar
Schex
Schex is offline
Received 7,046 Likes on 1,858 Posts
I still have all the stuff I removed...somewhere
Old 04-29-2012, 09:21 PM
veejay's Avatar
veejay
veejay is offline
2nd Gear
Yes, the CB controls. He has an intermittent loose connection that we traced to the CB control circuit board on the console on the gas tank. That thing is potted up and would be very hard to get to the solder pads on the board. We can talk thru email, PM, or you can post it on Ebay with a Buy It Now, your call.
Old 04-29-2012, 09:23 PM
veejay's Avatar
veejay
veejay is offline
2nd Gear
Thanks, see my other reply. I'm not normally on this forum, but my Google brought me here, and I have been a member for some time.
Old 04-29-2012, 09:25 PM
veejay's Avatar
veejay
veejay is offline
2nd Gear
Hey gunslinger, I just noticed you are in SW Missouri. I am in NE Arkansas. Might be, we could take a ride up there...
Old 05-01-2012, 06:13 AM
nyokie's Avatar
nyokie
nyokie is offline
Originally Posted by friend.b
I Searched for the plate/ mount, on both sites you suggested, but could not find the plate mount. I would like to keep the 2 person seat on there now , and possibly replace the tour pack with a sissy bar /luggage rack. and passenger back rest pad. if you have a link to the proper parts I would appreciate it. Thanks!!!!!
check softbrake.com for a under taillight tag mount cheap like 40, and i used led tag bolts for light. search my posts there is a part # for a taillight without the tag window in the top/ solid red
Old 05-01-2012, 06:50 AM
traildog's Avatar
traildog
traildog is offline
I removed the cruise and original radio, cb and dash controls, replaced clutch and brake switch brackets with standard clamps.
Ended up with about a 20lb box of modules and wires and junk.
Replaced switch housings and added the throttle friction thumbscrew.
I used the old wiring sheaths and wires to make factory looking harnesses for the new radio, speakers, and added power relay (to get full voltage to fairing gauges and accessories).
Man, that looks great! You relocated the speedo and tach as well, correct? That looks like a lot of work!
Old 05-01-2012, 07:15 AM
Schex's Avatar
Schex
Schex is offline
Stock location for 1990.
Old 05-01-2012, 02:02 PM
Mountainkowboy's Avatar
Mountainkowboy
Mountainkowboy is offline
Received 1,010 Likes on 544 Posts
You can make your tourpack removable with the later model stuff and a little dification, I did to mine.
Old 05-02-2012, 04:56 PM
Thomto's Avatar
Thomto
Thomto is offline
Best bet, get a service manual. You might have to get the electrical book too.
Quick Reply: Need help on 1990 fltcu tour glide
