badlands run/turn/brake module install issues
01-29-2012, 02:06 PM
I know I need to call badlands themselves, butits the weekend and their closed.
Got the module wired in, and only one side works properly. The other side operates only as run light, no brake or turn operation.
Any ideas? Thanks.
01-29-2012, 03:34 PM
What badlands module do you have?
What year bike do you have?
Are you running 2 lights or 3?
01-29-2012, 03:41 PM
Quote:
Originally Posted by
Tom84FXST
Bike is a 95 softail custom. The module I bought is the ILL-01B. I'm trying to run two LED lights as run, turn, brake.
Thanks for any help.
01-29-2012, 03:51 PM
HarleyReece
That module is custom made according to the website...Did they put the plug on for you?
01-29-2012, 04:06 PM
No, I had to put the plugs together myself. I tried hooking up the old brake light to see if that part of the circuit had anything to do with it. The brake light ended up being the right turn signal the one that wouldn't work). At least I know the switch on the bars are good, not sure what I need to do.
01-29-2012, 04:14 PM
HarleyReece
Looks like you solved the problem...hook the wires you hooked to the brake light, to the one that was not working.
01-29-2012, 06:25 PM
I tried that, and it only works as an on/off brake light.
Should I hook both power wires from the harness to the power wire of the brake, then hook the the ground wire to the negitive wire going to the light?
01-29-2012, 06:53 PM
HarleyReece
Didn't work. I'm at a loss in the solution dept.
Danuel1225
02-22-2016 06:27 AM
Powderhorn09
06-12-2014 02:12 AM
sportyguy69
04-29-2013 05:02 PM
clanker24
06-08-2009 11:19 AM
Mike1397
10-06-2006 06:13 PM
badlands ,
brake ,
current ,
davidson ,
forums ,
harley ,
hd ,
install ,
issues ,
kit ,
light ,
module ,
modules ,
run ,
shovelhead ,
signal ,
turn ,
turnbrake
