Solenoid Starter Push Button-EVO anyone?
Received 4,361 Likes
Taking a lap around the lake with my sweetie and pulled in at the top of the ramp facing up hill for some sunset pictures. Turning around and rolling toward the water didn't look like a very good option. The button on the handle bar finally kicked the starter over and the next day a new relay and manual button were ordered.
OK , back to basics . Prove your battery as good by having it " Load tested " at any auomotive parts shop for free . New batteries can internally short as well as old ( been there done that ) and will show false multimeter specs. unless under load. If your battery checks ok ., check starter solenoid/relays , dirty bar switch , wire contact points , last but not least ... starter motor itself.
No, it means anyone can crank the bike over. To start the bike requires ignition (spark), and that's on a separate circuit. Don't believe me? Try starting your bike with the solenoid push button with the ignition locked.
Yes they did. Mine had that style switch, but it worked lights in both positions and ignition in the last ('94/'95 peculiarity). On my bike it was simple to convert it to the old style day/night running positions. I don't know what would be required for a '96/up Softail. It can probably be done, but will require a bit more rewiring.
