Premature Signal Cancelling
Old 01-06-2012 | 05:19 AM
Harley89's Avatar
Harley89
Stage IV
Default Premature Signal Cancelling
I have an 1989 FLHTC Electra Glide. I added a couple more LED turn signals for more visibility, and I also have the Illuminator for 3 function tail lights. Previous owner had installed the Illuminator, to which I am just adding more LEDs too. Problem has just started, that when I put the turn signals on they work fine, activate either brake, foot or hand, they stay on, but once I release the brake, they stop flashing. Bike has electrical issues, which I am trying to trace down, because he installed an after market radio, and when I put on the turn signals, it would go off / on, but I think I've figured that out by moving the the radio key wire to another circuit breaker, and ground wire to seperate line. Thanks
Old 01-06-2012 | 08:15 AM
grbrown's Avatar
grbrown
The mysteries of bike wiring! I reckon the wiring harness engineers use the dark arts when designing them and we have to use black magic to solve any problems.
Best of luck. If we can provide any spiritual help we'll do our best!
Old 01-11-2012 | 10:03 AM
jdm1200's Avatar
jdm1200
Perhaps its you just need a new turn signal flasher. I just replaced mine because the turnsignals were acting screwy. Might flash 1,2 or 3 times and then cut off. Changed the flasher and they work fine. Also changed the Hazard flasher. You can get them at autozone or your favorite parts store. Mine work like new now. Now if I could only find that loose wire that is making my passing lamps go on and off.
Old 01-11-2012 | 04:53 PM
miacycles's Avatar
miacycles
They make flashers for vehicles that have added lights or tow a trailer. That may solve your problem as long as one of the wires to the new lights aren't shorting out. Hoppe this helps.
Old 01-11-2012 | 06:18 PM
Owtlaw's Avatar
Owtlaw
I'm not sure if the 89 wiring is like my 92, but there is a wire that is common to the flasher module and the radio. It's a white wire with a green trace that also connects to the speedometer head. It controls the speed sensitive volume and signal canceling by having speed input. If you have that wire.... check a diagram..... I'd start there first since both the radio and the signals are goofy.
Old 01-22-2012 | 07:43 PM
2-whlz's Avatar
2-whlz
off.
The flashers are the same ones used for 4 wheelers?
Old 01-22-2012 | 08:03 PM
bagga's Avatar
bagga
i changed the flasher on my 85 flht and i just used a 552 flasher from an auto parts store. about $5. it works just fine.
hdstevie
Electrical/Lighting/Alarm
06-27-2015 02:46 AM
backwods12
03-08-2012 11:26 AM
rhinodog
02-03-2012 10:36 AM
Harley89
01-06-2012 05:25 AM
jaypee
09-08-2011 10:16 PM
