My 1990 FLSTC 1340 Evo project
After the cam, you'll probably need to change up the carb jetting. That's the "carb work" implied. You could do some searching on the site here for similar setups and what needles they use, to give you a good starting point.
I used to hate EFI. Now, carbs are a PITA. With the Megasquirt stuff, (my Corolla, RN Truck, Dr.Linda's Sportster), it's just a matter of driving around, logging, adjusting the tune while you drive, or after you stop, etc. Too rich? Clicky-clicky, it's leaner. Kinda spoils you.
Assuming the engine is in good health and does not need to be rebuilt (that would really eat into your 2k budget)...
If the bike is still stock, then it has a CV carburetor, 1990 was the first year for the big twins and the CV carb.
It already has a Torrington cam bearing.
I am a big fan of the Andrews EV27 cam, it, combined with some decent free flowing pipes and correct jetting will really wake up the engine.
When you do the cam install, press the old gear off the stock cam and install it onto the EV 27.
If it is a high mileage engine you may want to replace the cam bushing that is in the cam cover, the best bet there is take the cover to a good independent shop and have it done, because the bushing must be reamed after it is installed.
I`m not a big fan of adjustable pushrods, they are great if you do a lot of cam changes, but after the second one came loose on my engine, I went back to the one piece rods and tossed the adjustables.
After many, many hours combing the interweb I think I zero'd in that the carbs are 40mm CV, and I do appreciate the confirmation of that.
As far as exhausts go, I really, really wanted to go duals with fishtails. To make that happen I am pretty limited, and it seems like a Bassani Power Curve is about the only header out there I can find specifically mentioning my model year as being a fit for a dual setup. Samson advised I can run their setup, but will have to make a hole in the frame for a bracket to hang the exhaust on one side (not a huge fan of this idea). My big concern here is that since this is a mild build planned, I may not be moving enough exhaust to make any positive gains and in fact may lose low-to-mid range torque (the exact opposite of what I want). Or least that seems to be the prevailing opinion.
Received 4,361 Likes
Serial
The mods you are doing almost exactly match the ones I have done to my '95 (which did not have a torrington bearing in it so make sure you check yours). As for the Samson pipes needing a hole (they are easy to drill and tap) I found on my frame two flat circles where the shole should be (and is on the newer bikes but has a plastic insert) and simplly drilled and tapped but I got one slightly off but it still works so if you decide to go that route be carefull.
Serial
I've tried to educate myself as much as I can on exhaust tech, and one thing I keel coming back to is unless its a 2-in-1 exhaust shouldn't they all be the same. After all, 1 exhaust pipe per cylinder has to be the same no matter how they are ran. Only differences would be is if they are equal length, and diameter.
What exhaust are you running and what motor is in your ride?
Engine and bike is in excellent shape for 20 yrs. I'm the 2nd owner and know its past. 21k miles, garage kept in climate control, and babied by the previous owner. The only thing is the black finish on the heads started to flake some years back, so it kinda looks haggard up close if you are picky like myself.
Thanks,
JR
Serial
Unfortunately for the OP, '95 was the first year the Softail frame got the left side mount for duals on the frame. My '94 lacks the left side mounting holes, and that's why I settled for the 2 into 1 pipes.
Harley used to offer a dual pipe setup for the older Softails, but it used a "mickey mouse" bracket for the left side that mounted to the swingarm pivot, and I didn't like the looks of it.
THC, when you did your build, did go the true dual exhaust route like the Touring models? If so, did you lose any low-to-mid range torque that you could notice?
I talked to friends and read a lot about exhaust before I did it the first time and the result was that while you do lose horse power going the dual rout unless you are racing it ain't missed. I damn sure don't have any complaints about my current set-up I just ride.
As for what brand of exhaust I have the real answer is I don't know. They don't have any markings. I found them on craigslist for $150 had to add baffles (couldn't get the motor to run right without them) and put them on.
I am running a stock evo with a EV-27 cam, screaming eagle ignition, and S&S carburetor. I never could keep the CVO carb in tune but the S&S was easy to set right.
