Front Fork/Suspension Options
I have a 1989 FLHTC and the LH fork has started leaking enough for me to have to do something about it.
Anti-Dive has not worked since I got the bike and future plans include new bars. I don't really care if I keep the front air shocks or not.
So where does that leave me with options?
I know i can reseal and put them back on or have my indy do it, but I'd love to upgrade while the fairing is off and they are being resealed. Progressive springs? or what else?
I installed a set of front Progressive Springs back in 2005...They are still working fine today and made a great improvement in handling...
The springs that were removed had been "cut" to lower the front...That made the lower fork legs bottom out quite often and reduced the fork travel to 2-inches at best!!
I have a new Sportster and have already changed the front forks. I fitted single rate springs matched to my weight with Emulators, all from RaceTech. I can't say I'm bowled over by them, but they are an improvement over the stock set-up. With your bike (I also have a 1990 FLHS) it is easy to sort out the air forks, but if you prefer, remove all the external stuff and replace the springs, as they are too soft to work on their own. Dual-rate springs are unnecessary, if you buy springs with the correct spring rate. Go to a suspension specialist who will ensure you get the right rate, don't guess!
I have custom-built Ohlins rear shocks and am waiting for the release of front forks with Ohlins cartridge inserts. I'll turn this ole lady into a Rolls-Royce yet!
Check this site out very good info and How To.. films to free .
http://www.motorcyclemetal.com/gpage1.html
I would like to get rid of the front air ride also, prob is, is that I have an fxrs-sp that has longer tubes, and no one seems to makes parts for this animal! The springs offered are stock length, no help, mine are longer, can't find my manual at this time, but trust me. Folks claim how great the fxrs-sp is, which I do not disclaim, but try to find parts to fit, my only beef. Otherwise I"ll ride it to hell and back.
