Brake upgrade on my 1984 FLHTC
10-06-2011 | 03:34 PM
Your 6 gallon tank would prove that theory ;-)
10-06-2011 | 05:05 PM
Quote:
Originally Posted by
Spanners39
I may sort it out yet!
10-06-2011 | 06:44 PM
grbrown
A man needs a a mission in life
10-06-2011 | 11:34 PM
Dont forget that you will need the late model M/C for them to worK properly also.
10-07-2011 | 08:43 AM
What if I just put on the entire tripple trees and forks from the donor bike, its a 96 Road King I believe. That would work right?
If I do this I may go ahead and change handlebars and add chrome controls anyways.... These projects have a way of snow balling.
10-07-2011 | 08:47 AM
You may find the 96 fork legs will fit your trees, but if the whole set is available that should cover you for every eventuality.
10-07-2011 | 10:49 AM
the 96 still has the single piston brakes on them doesnt it? my 95 runs the stock front wheel and discs with a set of 2006 fork legs and calipers, I used a brass bushing in the fork legs to pad them out but some use the 1" axle and just machine down the centre to make it fit the original wheel.
made a huge difference to mine!
Z
10-31-2021 06:14 PM
skypilot_one
11-12-2015 10:18 PM
jsl6v8
04-28-2015 11:32 PM
Wireguided
09-13-2012 10:12 AM
equandt
12-12-2009 07:54 AM
1990 ,
1998 ,
95 ,
bat ,
brakes ,
caliper ,
eagle ,
flhs ,
flhtc ,
harley ,
ignition ,
module ,
narrowglide ,
pics ,
screaming ,
upgrade ,
wing
