98 fatboy evo - going to single fire ignition
I am moving to Dynatek ignition, and not sure if I should go with the Dyna 2000 or Dyna 2ki? I know the Dyna 2000 is an easier install, but not sure if I need to replace my stock ignition under the seat which is a 32449-95a (ignition module) ?
Other parts currently on the bike are 32448-95b (cam sensor) and 31614-83A (coil).
Seems the Dyna 2000 kit (sfk-3p) replaces the 32449-95a (ignition module) and 31614-83A (coil)................. but the Dyna 2ki kit (d2ki-5p) replaces the 32448-95b (cam sensor) and 31614-83A (coil),,, but leaves the 32449-95a (ignition module) in place??
Is this true? I am not clear... Can anyone clarify, thanks.
run1fsr
11-26-2014 07:57 PM
