Oil cooler question
Oil cooler question
Hi all. I have a 1991 Electraglide (oil filter located under the bike behind the transmission) Does anyone know if it is possible to install a oil cooler with a oil filter relocation setup. The ones I have seen are all for the bikes with the front mounted oil filter. Any help appreciated.
Thanks
Thanks
Thanks for all the replys, I already have a used lockheart cooler but I'm not sure where to connect it and what lines to extend. If I can skip the relocation (filter) part and just connect it to the existing oil lines that would be great. Does anybody have a diagram or an explination of what lines I need to extend and where they are located.
Thank you again
Siberia=No Obama......Sounds good to me!
Thank you again
Yes, as mentioned, nothing but hoses is needed. I also suggest a thermostat. Either get a cooler with one built in or get a separate unit like this one:
https://www.denniskirk.com/_.p31384.prd/49218.sku
if you can find one. It looks like that is NLA. Maybe someone else makes one or you can find a new-old-stock item.
Thank you again
Thank you again
