Tappet screen cap
Sometime you can get a centerpuch or small chisel to work. You may have to use a dremel to grind a spot on the plug so you will have a good flat spot for the chisel to bite into it. Just tap it lightly in the loosening direction.
Or you could even use the dremel to just grind on the notch to make it cleaner The bit will stay in the notch then and not try to slip out.
Get one of these very handy with aging iron , absolute must for most cases like yours .
http://www.amazon.com/Lisle-30200-Ha.../dp/B000P0TZ9W
Yep twisted hit the nail right on the head. They are available from Harbor Frieght/Northern Tool for a very reasonable price. While you are there you can also find a suitable 3/8" drive screwdriver socket to go with it. By all means replace them with a set of either socket head or hex heads pieces. When installing them, no loc-tite and remember they aren't head bolts!!!!
