replaced rear master cylinder, all brake lines and fittings, hose etc....no brakes!
Old 08-08-2011 | 07:07 AM
jsbridgew's Avatar
jsbridgew
Speedbleeders are pretty cool to use, too
Old 08-08-2011 | 01:00 PM
miacycles's Avatar
miacycles
+1 on the speed bleeders. We put them on every system we do. It makes a two person job a one person job and they flat out work!!!
Old 08-28-2012 | 07:25 PM
caleb895's Avatar
caleb895
so i guess the cylinder was in upside down since this forum stopped all at once.....lmao
Old 08-29-2012 | 06:57 PM
machinehed's Avatar
machinehed
Many tips from everyone and hope it all helps with your troubles.
Have found that bleeding bike brakes are a real pain.
A few suggestions ... if the m/c is original , drain it and use a wet/dry vacuum cleaner to suck up possible crap lodged in a very small orriface located at the bottom of the m/c resivour. Have found that this pin sized hole will clogg and prevent normal bleeding .
Rebleed m/c and try to bleed system again . Be sure to top off resivour while bleeding system as any air entering during procedure will send you back to square one.
Old 08-29-2012 | 11:07 PM
Wakko47's Avatar
Wakko47
I really like that backwards method...seems like the easiest way to do it!
D-Rak
02-01-2019 09:10 PM
prplglide
Wheels/Tires
10-23-2013 06:54 PM
GLIDEGASM
Wheels/Tires
08-07-2013 07:43 AM
ggibson
12-05-2009 07:35 PM
fogcity123
EVO
10-15-2008 05:19 AM
Quick Reply: replaced rear master cylinder, all brake lines and fittings, hose etc....no brakes!
