Blown head gasket
#81
Ok, after putting a couple hundred miles on it, the exhaust nuts on the rear cylinder came loose and fell off, and a couple of the clamps came loose as well. I got new nuts and replaced them on the rear cylinder studs and retightened the front ones. How tight are these supposed to be to keep this from happening again?
#82
#83
#84
#85
Been doing my homework going through the archives here.
D1gger,
I want to thank you for this thread. I also want to thank all those who were involved and added so much info. I've been taking notes.
Any updates as to the outcome a few years later?
I started a new conversation on my issues here: '86 Tour Glide, EVO Main Gaskets Leaking
Last edited by JohnnyC; 01-24-2014 at 09:20 AM. Reason: Moved questions to a new thread.
#87
#88
Make sure it is not a cracked exhaust pipe, This past weekend I had to pull the exhaust because the header pipe cracked just where it comes out of the head, I could feel the exhaust blowing out but didn't find it until I took the exhaust off.. Just a thought.
#89
FWIW I have never encountered a pulled or stretched head stud but then bikes get messed with far less down here than in Americky.
Blown head gaskets can have many causes and the usual suspects as far as I can see are:
Incorrect torqueing of head at some point.
Stuffed base gasket
Cheap, nasty gasket sets (no name brand....you sometimes see them)
Very high miles
Overheating in parades etc.
#90
Thanks Spanner.
I decided to start a new thread about my specific issues after all. I think it might get more answers that way.
