Irratic clutch cable to perch = bad spring plate
Old 07-14-2011 | 12:54 PM
Sam07's Avatar
Sam07
Default Irratic clutch cable to perch = bad spring plate
Hi All,
Just wanted to help the next guy out....
Symptom: Randomly when pulling in the clutch to come to a stop, I could not shift gears as if the clutch lever was not pulled in all the way. When I got the trans in Neutral, I could pull the clutch cable out of the perch about 1/2 an inch. Way out of spec for adjustment. I must have adjusted the cable 4 times and magically it would work ok for a little while. It was really noticeable when the bike was hot.
Cause: Clutch spring plate failed shearing off rivets and inner material to wipe out the other discs. I caught it early enough and saved the clutch basket. Otherwise, grenade!
Correction: New Barnett clutch installed eliminating the spring plate and adding two more clutch discs.
Old 07-14-2011 | 01:13 PM
mtnlvr's Avatar
mtnlvr
Thanks for the heads up!
Old 07-14-2011 | 01:14 PM
jsbridgew's Avatar
jsbridgew
yah, my next purchase is a Barnett clutch
marktruckee
EVO
07-10-2018 12:40 PM
danny54
10-21-2012 03:24 PM
Cruisers2
09-11-2011 11:08 PM
pistole
EVO
17
03-19-2009 01:54 AM
jcarson
Ironhead
16
04-26-2008 02:48 AM
Quick Reply: Irratic clutch cable to perch = bad spring plate
