Piston caliper lube ??
Got the rear caliper piston in yesterday. Still a bit busy at shop to work on it. There are some instructions in the package thought I` d read them. In the instructions it says DO NOT use dot 5 fluid to assemble the caliper. Use only the piston lube supplied. I`m sure there are reasons for this. If someone has the time I`d appreciate being enlightened. If I hadn`t read the instructions I`d dang sure used the dot 5 brake fluid Thanks for your time folks WP
Wanting to make sure I get this right the first time. Good lord I sounded like Mr. Goodwrench Nah I gotta ask.
If this had to go together tonight it would be with the Dot 5 Thank You Sir WP
Brake fluid will work, however if you have the lube use it. It really doesn't take that much to install the seals. basically you are making sure that the seals can move and find the spot they want to run in. There is also a high temperature grease that you should use on the pins that the caliper should float on and/or the pads slide on. Hope this helps.
I'm following this thread as I'm picking up a caliper and master cylinder rebuild kit tomorrow from the dealer for my wife's '89 softail. Her rear brake caliper started seizing up on the rotor last week while on the Interstate. Got so hot it turned it blue. Warped the rotor to the point it was rubbing against the caliper bracket. Replacing everything this weekend. I hope these rebuilt kits have at least some instructions. The caliper looks pretty simple. Master Cylinder looks to have a few more moving parts.
