Piston caliper lube ??
Old 07-14-2011 | 09:49 PM
WP50's Avatar
WP50
Originally Posted by Spanners39
When doing the M/Cyl rebuild it is essential that you clean out the feed and return holes in the bottom of the resevoir and flush the whole thing as blockages in the return can cause brake binding.
Thank you Sir I have flushed and cleaned every opening and orfice I can find on this system. Brake System Thanks again WP
Old 07-15-2011 | 10:48 AM
BB4xl's Avatar
BB4xl
When re-building the Master cyl you will need Snap-ring pliers. At least I did on mine
Old 07-15-2011 | 05:21 PM
Spanners39's Avatar
Spanners39
You will also need 2 beers and some cool 70's biker posters on the wall, and a decent Rock Station on the radio....CD's and albums do not create the right vibe
Old 07-16-2011 | 07:20 AM
WP50's Avatar
WP50
Sounds like we might use the same decorator and Bud or Bud light? BG WP
Old 07-16-2011 | 10:01 AM
TwiZted Biker's Avatar
TwiZted Biker
Use the lube or you may find getting that piston back into the caliper isn't so simple . Dot5 doesn't have any lubricating qualities to it at all , may feel slick but isn't . Under pressure like pressing a very close fit piston over that o-ring DOT 5 will grab not slide that's the problem . Any heavy silicon based O-RING lube for should work in a pinch and is compatible with DOT 5 .
Old 07-16-2011 | 05:45 PM
Spanners39's Avatar
Spanners39
Down in this part of the world you'd get deported for drinking Bud Light Monteiths is what I drink....but Speights or Lion Red will keep you from getting the bash too....
Biker Bob
05-29-2018 02:23 PM
rufasim
05-03-2015 01:17 PM
Napalm Dog
02-24-2015 07:51 AM
Krazyshark
Ironhead
08-31-2012 11:13 PM
chikenfat
11
11-02-2010 07:37 AM
