whats enough oil pressure
My '98 Ultra with around 70,000 miles....has never had much oil pressure. At idle and the motor is super hot....I never get over 5 according to the factory oil pressure gauge. Going down the road, I might get around 15. When the motor is cold and is cold outside...I've often seen the oil pressure gauge max out.
I've never worried much about it. If the oil pressure light comes on....then I might get concerned.
Thats exactly where my '96 is at. In fact, if I get stuck long enough in dead stop traffic when its really hot out, I can have much lower pressure at idle than even that. But as soon as I start moving it shoots right back up to my normal numbers.
Mine too, its been that way since new and has 88,000 on it. 88' flhtc anniversary edition
You need to do your homework before you attempt to adjust oil pressure. You do not want it to high at idle since the piston oil jets which are like both lubrication and cooling for the piston are set to only work above 12lbs so as to not over lube the cylinders at low rpm. These roller bearing engines since they are so different should probably just have a light.
Worst thing I ever did was put an oil pressure gauge on my bike...you are better off not knowing..lol. When I crank my bike it is 35 psi @idle...on a 90+ degree day,once the motor gets up to operating temp, it pretty much sits on zero @ idle. I have it idled very low...but I have had the bike for 15 years with no problems.
