carb question
Old 07-05-2011 | 10:52 PM
patharley's Avatar
patharley
Default carb question
I just put a jet kit on my cv carb (95 softail)... BUt I mess with the idlw srew.. The screw head is stripped. Can I bought this screw, drill the old one to put the new one or which way I can change it.
Old 07-05-2011 | 11:01 PM
schwangster's Avatar
schwangster
not sure which screw you are talking about, mon ami Evo.
But put away the BIG tools for a while, until you get a correct answer.
No drills, no hammers, no sharp tools.
Help is on the way. (I asked some friends for answers)
Old 07-06-2011 | 12:05 AM
Spanners39's Avatar
Spanners39
Drill a tiny hole in the head where the screwdriver slot used to be, get a small square section steel rod that has a tapered end, looks like a spear or a file handle. Tap it into the idle screw and turn it slowly out.
If the idle screw is seized in then you may need some heat.
You can buy an idle screw easily enough.
Old 07-06-2011 | 08:28 AM
grbrown's Avatar
grbrown
Can you post a photo of this screw, so we can help out? We're reaching across the Continents here!
We must have some Quebecois on HDF who can help in French?
Old 07-06-2011 | 03:32 PM
95yj's Avatar
95yj
Do a search on Google for "Keihin idle screw harley" and you'll come up with this: http://www.google.com/#ds=pr&pq=keih...w=1281&bih=851
As far as getting it out, my favorite method on stuff like this is using a left handed drill bit. A lot of times the drill bit will back out the screw all by itself and you won't even need to try to grab the screw with something else after drilling a pilot hole.
En ce qui concerne le sortir, ma méthode préférée des trucs comme cela est d'utiliser un foret gaucher. Un grand nombre de fois que le foret sera de retour sur la vis tout seul et vous n'aurez même pas besoin d'essayer d'attraper la vis avec quelque chose d'autre après le forage d'un trou pilote.
Old 07-06-2011 | 03:40 PM
grbrown's Avatar
grbrown
Good man 95yj! I've just discovered where Aruba is - must be tough down there! We had hail and rain today....
Crusader
Exhaust System Topics
04-14-2021 08:51 AM
cavscoutjim
06-04-2012 02:22 PM
halmc
Ironhead
05-05-2009 08:26 PM
supr2nr
Ironhead
02-19-2008 08:26 PM
Otter
01-10-2006 12:45 AM
Quick Reply: carb question
