Wrong brake fluid used ??
Mine applys the brake some but has a very hard pedal (least compared to what I`m used to and comparing it to a couple of other frinds HD`s. Have seen what you speak of and in other cases ther was little to no problem. I`m wanna do this with no shoulda woulda coulda thoughts Thanks you Sir WP
DOT 5 should be available from any Harley dealer or indy. Be aware that there is also DOT5.1 and that is NOT compatible with DOT5. Whoever it was in DOT who chose that name should be shot!
I bought my 1990 FLHS new and used whatever brake fluid I could for the first ten years I owned it, not realising the significance of the different DOTs. What I found at around ten years is that I started getting black traces coming out when bleeding the brakes, so I stripped and cleaned everything.
Both master cylinders were full of a cloudy jelly and the internal parts were seriously corroded. The worst thing, however, was that the cylinders of both were also corroded, by which I mean the surfaces were dull grey, not shiney, but also parts of the surfaces had been eaten away. The calipers had similar problems.
I replaced the entire braking system, at huge cost! It was as close to being shot as I cared to allow it.
So don't mix brake fluids!
DOT 5 rocks. I bought my bike new. I opened the box at the dealer, actually. I was having a soft rear pedal a couple years ago. I know that the rear brake fluid has not been touched in >20 years. I checked it a couple times way back when, nothing ever changed, so I left it alone. I fully anticipated the whole system to be junk when I tore it down. What I found was a perfectly clean system with very minor wear marks. I put a new kit in both and then found my problem was probably a leaky joint at the hose connection on the swingarm.
M1 Abrams Tanks use DOT 5. So, you can get the same thing in a Mil Spec can cheap. How's $30/gallon sound?
http://cgi.ebay.com/ebaymotors/1-Gal...Q5fAccessories
That would be a U.S. Gallon, there, Graham.
Start with flushing what you have. Drain it, run some brake cleaner through it all, disconnect the line at the MC, open the caliper bleeder, hook up an air hose and blow it all clean. Fill with DOT5 and flush a bunch with that. See if it works. If you didn't get a bunch of black stuff (your seals) come out with the flushes and the brakes work, I thinkyou'll be OK, otherwise get some rebuild kits (seals) and rebuild the MC and caliper.
Certainly hope I don`t have to go that far BG I learned along time ago not to mix fluids. Over the years have seen quite a few brakes systems screwed up. The simularity in the old style bottles of Brake fluid and Power steering fluid was a cause. I had seen a parts guy putting P/strg fluid on a brake fluid self more than once. Not so much now but in past the bottles were to much alike. Thanks for your help WP
but you cannot mix 3/4 and 5.... spanner 39 says he has a jar of it mixed with no problems .....I had it in my brakes lines and it was one unholy mess ....jelly everywhere and a hard as rock lever that wouldn't put the brakes on ...had to drain and flush all lines and disassemble all rubber parts to clean/replace even the master and then reload with 3/4
It looked like a jellyfish hab been in my calipers a translucent greenish colour ...after the cleaning and removing all rubbers and cleaning behind them ..it was fine .......
and even race cars are going away from using it as it doesn't work well at all temps just extreme temps
I'm not saying it doesn't happen but I think its a reaction with the seals that causes the problems and the jelly is rotten rubber or something.
I have some old brake parts, I might add my mix to a brake system (off the bike) and do some more testing...
