89 FLHS ignition?
Old 06-30-2011 | 03:08 PM
dkfxr's Avatar
dkfxr
Default 89 FLHS ignition?
My bike started missing upon acceleration yesterday. Starts fine and idles fine. How do you tell if it is ignition or the carburator?
Old 06-30-2011 | 04:22 PM
Dr.Hess's Avatar
Dr.Hess
Do you have a tach? If the tach is stable, then it's the carb. If no tach, you can get a little pen like device that will flash when held next to a firing plug wire. Gets a little complicated holding the device next to the wire with the button on while you accelerate to make it miss, but it's possible.
Old 06-30-2011 | 04:28 PM
dkfxr's Avatar
dkfxr
Thanks, I will start there. I do have a tach.
Old 06-30-2011 | 05:21 PM
Dr.Hess's Avatar
Dr.Hess
If the tach is stable, it is still possible that the plug wire is shorting to ground or the plug is fouled. To check the plug wire, grab it while it's running. If it throws you across the garage, it's bad. I believe there may be other tests for that too, but somehow that one always seems to be used. New plugs never hurt. However, a tach signal means that the ignition module, pickup, ignition wiring, etc. are OK.
Old 06-30-2011 | 06:19 PM
Havoc88's Avatar
Havoc88
I love that test NOT! done it a bunch and its almost always on accident.... kinda LOL
Old 06-30-2011 | 06:41 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The best method is to get someone else to grab the plug wires...
Old 06-30-2011 | 07:58 PM
JohnnyC's Avatar
JohnnyC
The list is long.
If your lucky it may be just loose or corroded connections on the battery.
Ignition module, cam sensor, coil and the ignition circuit breaker.
Also fuel line, tank vent, plugged tank filter. And even bad gas.
Uncertain if you have EFI or carb? Carb could have a float bowl issue starving the gas flow.
And to add to the aggravation it could be an ignition module that works correctly only part of the time.
I had that issue and discovered it got progressively worse. The real issue was that if you shut off the bike and restart it it worked again for a while. I discovered you had to leave the ignition on when the bike faltered and test for spark without shutting off the key and turning it back on.
If you discover it's the ignition module you may want to upgrade to one a lot more programmable to improve your performance ... just by changing the module.
And last would be corroded contacts, broken or damaged secondary wiring.
Good Luck.
Old 06-30-2011 | 08:34 PM
dkfxr's Avatar
dkfxr
Thanks for all the hints, looks like a busy weekend,
Old 07-01-2011 | 02:49 AM
grbrown's Avatar
grbrown
Talking
Here's hoping you manage to stay out of Emergency.....
Old 07-01-2011 | 01:27 PM
NutterFLH's Avatar
NutterFLH
First of all, change the spark plugs and clean the carburettor.
Might be faulty VOES , too.
