CV carb choke mount
Old 06-10-2011 | 05:42 PM
the_ogre25's Avatar
the_ogre25
Default CV carb choke mount
I am getting ready to swap a CV carb onto my 88 FLHS. My question is about the choke mount. Does anyone have a pic of a stock mount on a touring bike or what you did to mount it?
I am thinking I can slot my mounts that I have now and make it work but am wondering what it should look like, and cant find any pics in my parts or service manual.
Old 06-10-2011 | 05:56 PM
95yj's Avatar
95yj
Here's a '93 Heritage Softail.
Old 06-11-2011 | 08:08 PM
the_ogre25's Avatar
the_ogre25
Thanks 95yj. One more question, for those of you with 90 and newer touring bikes. Is there a strap that runs down from the motor mount to the v between the cylinders, or does the horn mount right to the top motor mount?
Old 06-11-2011 | 08:46 PM
owend78's Avatar
owend78
That mount looks similar to the one I had. It looks like an upside sown U. The bracket mounts to the bolts that the engine mount is on. Horn and choke cable are attacked to that. Am getting ready to fabricate my own, as this part is now obsolete from HD. I can take a picture of what it looks like on my bike on how it is set up if you like, although I don't have a touring bike, it's a Wide Glide. But since it is broken you can see how it is mounted and how everything is attached quite well.
Old 06-11-2011 | 10:02 PM
Quadancer's Avatar
Quadancer
Easy enough to fabricate, but if you use the stock plastic nut or not, you don't want to overtighten it - takes very little to hold it and will strip if you do. (according to the manual)
You can fob the **** too - I thought my Heritage looked something like a buffalo...so we call her "Buffalo Gal" and I put this on my ****, with a bit of filing and epoxy:
I got the idea from some guys who used pennies the year of Harley's inception on theirs.
Old 06-12-2011 | 02:01 AM
Bama91's Avatar
Bama91
Don't know if it will work for you but Yost makes a CV top cover with a choke cable bracket on it. Dennis Kirk P/N 49-3587 $56.99. That is aluminum polished smooth top. With the Yost logo is P/N 49-2954 Same price.
Old 06-12-2011 | 08:04 AM
miacycles's Avatar
miacycles
Take a piece of aluminum angle iron, cut a slot in one side that the choke will fit in and bolt/pop rivet it to the back of your air cleaner where you can get at it. This will give you a neat, clean mount. Hope this helps.
Old 06-12-2011 | 09:21 PM
Quadancer's Avatar
Quadancer
Huh??? Choke goes out the left side...air cleaner?
Old 06-12-2011 | 11:48 PM
Spanners39's Avatar
Spanners39
Choke goes on the left with a CV, you can mount it on the right but it is far easier to push it in when riding if it is on the left.
Old 06-14-2011 | 10:49 PM
IDIDNTDOIT's Avatar
IDIDNTDOIT
I much prefer the choke on the left so my right hand can still run the throttle. I bent my original choke mount around a little and it worked with the stock CV choke cable. Mine is an '87FLHTC.
Quick Reply: CV carb choke mount
