HELP Did I just ruin my inner primary?
I was cleaning it up and popping out the bearings and seals...........A little TOO MUCH dig with a chisel (I KNOW!) getting out the starter bendix seal. Is it ruined or will I still be able to get it to seal up? Also the brass bushing that is still in, should it be changed while the inner is off? I can take more pictures if needed.
Nah mate, she'll be right! A little JB Weld sorts many errors.....I actually think it would be OK as it is because the seal does the work, the alloy just gives it a home but bearing in mind what a big job removing the primary is I would do the JB weld thang.
Bushes don't often give trouble but as you have been a naughty boy with the chisel I think you should replace it by way of a fine or punishment...
Nexus9
05-19-2017 07:26 PM
