Barrel Gasket Leak Fix?
Old 05-03-2011 | 12:28 PM
PKS98S's Avatar
PKS98S
I let some fellow riders and 1 HD dealer talk me into synthetic on my 99 Heritage with 50k. I put Mobil 1 V-Twin 20W50 in and drained that crap out of there within less then 500 mile - "BIG" waste of money. Went back to Castrol GTX 20W50 and all is well again. Still have a very small weep at the left rear of the rear jug base and right front of the front jug base but it's a Harley.
Old 05-06-2011 | 07:28 PM
ultrashovel98's Avatar
ultrashovel98
4th Gear
Post whats. happening.
] I'd like to say hello this is my first time on the site. the site is awesome. I just picked up a 98 ultra with the rear base gasket leaking. I heard a rumor that 3 m windshield sealant will help slow it down. I've never been a believer in the quick fix , but it actually works. it comes in a metal caulk tube at the auto parts store. mine was bubbling m blowing everywhere after I cleaned it up with brake cleaner very good I ran a bidet of sealant along the surface , making sure to hold it tight as to force it in the gap. that was a bout 500 miles ago and compared to what it was,it's dry. should have no problems getting through till winter as for right now, I'm slowly collecting gaskets and anything else I might need. I have 27,000 miles is there anything I should be concerned with at this point in time? pistons,lifters,rings? thank you for any help you could be and good luck with. The fix.
Old 05-06-2011 | 09:40 PM
hatchetman's Avatar
hatchetman
I think your engine has a timing chain & tensioners. They do require regular servicing but if I owned one, I would pull that Flintstones garbage out & run a gear drive system.
your mileage is low, your worries are a few years down the road!
welcome to the forum!!!
Hatch.
bparsel
EVO
27
05-06-2021 07:01 AM
dlnp22
Oil Archive (no new posts)
09-21-2009 03:16 PM
jn2jhavens
Exhaust System Topics
08-31-2008 01:16 PM
alwaysarider
Shovelhead
06-10-2008 12:08 PM
BiggestDawg
02-25-2008 05:41 PM
Quick Reply: Barrel Gasket Leak Fix?
