Primary Belt Drive Anyone?
Old 04-08-2011 | 06:01 PM
Tactical111's Avatar
Tactical111
Question Primary Belt Drive Anyone?
Recently put a Rivera Primo Brute III Primary Belt Drive kit on my '91 FLHS to get rid of an oil leak at the inner primary cover to case area.
Tranny leak got on belt and took it out in the first 200 mi. Now have the tranny leak fixed and new belt and am happy with it other than the noise after about 1000 miles so far.
Have the stock outer primary cover on with vented inspection and Derby covers. ( Derby cover is actually just a mesh so very open)
Question is how many miles can I expect out of that primary belt assuming normal operation and no oil getting on it?
Also if you have one how do you like it?
Old 04-09-2011 | 05:01 AM
Spanners39's Avatar
Spanners39
Should last at least 30,000 miles if you don't run it too tight or too loose. I had one on my Sporty and took it off because there was a bad batch of belts that broke after like 1500 miles and the dealer couldn't and wouldn't guarrantee them after refunding me for the first one.
Old 04-09-2011 | 05:48 AM
perpulreaper's Avatar
perpulreaper
Got any pics
Love to put one on my ride
Old 04-09-2011 | 07:02 AM
bigtone's Avatar
bigtone
I had a primo setup years ago on a shovel FL I used to own. Ran it just like yours, with the vented covers. Over a year or 2 it broke twice on me, I said the hell with it and went back to a chain. I think the problem is that any oil vapor will ruin the belts. And in a semi enclosed primary you have alot of oily vapor and heat. Mine literally blew apart both times. And there was no fixing one of them on the side of the road. I think the open ones last alot longer
Old 04-09-2011 | 07:22 AM
hotrod351's Avatar
hotrod351
have one on my 90 fxstc, 14000 miles on it. no problems yet. people think how cool it looks, and sounds. i almost went with the closed belt but changed my mind at the last second to the open.
Old 04-09-2011 | 11:14 AM
2006FLST's Avatar
2006FLST
I had the brute III set up on my old evo before going with a BDL 3 inch open. It ran fine but I only put about 5000 miles on it. One thing you can do is look for a fully vented outer cover. Basically has a bunch of slots all in it.
Old 04-09-2011 | 03:28 PM
Tactical111
Thanks for all the input, guys. I'll check into that fully vented primary cover. Pics of my primary ( assembled) are in my garage. Avatar shows a close up of it right after I had it put on.
I like the idea of a chain much better too for the primary drive. Just got sick of the dang oil leak. Now I find out there's an aftermarket gasket that supposedly seals that cracked primary area without changing anything else. Wish my wrench had been up on this technology.
Old 04-09-2011 | 03:36 PM
Stiggy's Avatar
Stiggy
3" or 4" Belts will last forever. Less than that, like the type designed for under the primary cover, are designed for only 12,000 miles. (It said so right in my instructions.)
Old 04-09-2011 | 03:41 PM
Tactical111
Thumbs up Primary belt wear...
Thanks, Stiggy! That's what I was looking for; a ballpark on when to replace it before it fails.
Old 04-10-2011 | 12:10 AM
dgdamore's Avatar
dgdamore
I've been running a 3" open Karata for 15+ years w/ no problems.
Tizza1013
Shovelhead
17
06-07-2020 01:44 PM
Larry64
EVO
11
03-30-2019 07:13 PM
polish hammer
EVO
16
10-05-2012 08:42 AM
shortride
04-29-2010 01:03 PM
jwcholland
Shovelhead
08-14-2008 12:33 PM
Quick Reply: Primary Belt Drive Anyone?
