Runaway Throttle S&S Super E Carb
Hey guys, I need your expert help with this one: I rebuilt my S&S Super E Carb with the master rebuild kit a few weeks ago. After re-installing the carb, I took the bike out for a test ride. The bike ran great for a couple miles: faster and more responsive. Really running nice. Then the throttle went to wide open. I tried to roll off the throttle, but it remained stuck at wide open, so I shut it down and coasted to a stop. Tried restarting several times, but the throttle was still stuck wide open. I thought there might have been binding in the cables, so I replaced the throttle and idle cables with new Barnett cables. Went for a test ride today and the throttle stuck and went to wide open again after riding less than a mile. Fairly certain it's not the cables, so I must have done something wrong during the carb rebuild. Maybe over torqued something.... Any ideas on how to troubleshoot the carb is appreciated. Thanks!
Thanks Dr Hess. I don't think it's a binding problem with the cables. When it happens I can still operate the hand grip normally (without binding), but the engine spools up to wide open throttle and stays stuck there until I shutdown the engine. If it were a binding cable, I would think the throttle setting would remain constant. Almost seems like the accelerator pump pushrod is stuck or something. I can't recreate the event in the garage, the butterfly plate operates normally there. Only happens when I'm out riding. What I plan to do next is to readjust the cables per the SM (third time) and then run through the S&S Quick Tuning steps to see if any of the carb adjustments are out of whack. Not sure what to do if that doesn't work...
Hmm, checked out that PDF and see that the "E" and "G" carbs have two cables? Mine only has one; I know this because I replaced my handgrips on both sides and there is only one throttle cable going to the handle bar??? I have an S & S "E" carb that was put on with my top end job about 6 yrs. ago.
Sounds like you might have left a spring out or that return cable is binding up somehow or coming loose??
