Are there any known issues with the Evo?
I've done a search and browsed as many threads as I can but other than the cam bearing issues with the INA bearing I can't find any known issues with the Evo.
Are there any known issues that persistently affected these motors? Or anything else I should be aware of would be much appreciated.
To be more specific I'm thinking about a Heritage Nostalgia (Special) from 93 --> 96.
No! I have owned my 1990 bike from new and during the first three or four years several things went wrong with it, but once fixed they have never happened again. In other words the likelyhood of past Evo 'problems' causing problems today are very slight, so they are not persistent.
As an example once replaced the INA cam bearing is done and dusted, but there are probably hundreds of thousands of them out there giving reliable service, unaware they are supposed to be a problem! I wouldn't even bother to check a bike unless going into the timing chest for another reason.
If you are buying one today any problems previous owners may have had with it will have been fixed and there is little you should trouble yourself about! And there ain't nuthin' we can't fix on here!
Go out into the big wide world and get yourself one soon!
