Carb fitting.
Old 03-03-2011 | 05:48 PM
tc's Avatar
tc
Cool Carb fitting.
Re built top end and fitted ev27, all went well and went for a run last Sunday. Funny sound from top end, like a scraping noise. Had bike striped again in my mind thinking a ring had broke or something, but bike ran great except for spitting and f**ting and scraping sound.
Got home and had a good listen. Definitely from top end so decided to spray intake manifold with wd40. Sound goes and bike sounds better, cool simple, (well more simple than a top end strip).
Took carb, S&S, off and discovered that the flange on rear cylinder had broken, I will put up hand and say I screwed up and must have over tightened bolts.
Now at last a question.
In the S&S instructions it says to fit manifold and bolts but do not tighten fully, fit carb and fit air filter backing plate then tighten manifold bolts.
How the hell do you get at them?????????
It is hard enough to get an alan key in with carb etc off, but with all fitted!!!!!!! Is there a special tool?
Thanks.
Tony.
Old 03-03-2011 | 06:45 PM
bikerlaw's Avatar
bikerlaw
Grind your Allen wrench down to a nub like this. You can get them tight, but it takes time. You can also pull off the gas tank and get to them from the top.
Old 03-03-2011 | 06:47 PM
miacycles's Avatar
miacycles
You need to tighten them down before you put the carb on.Just make sure that it is aligned properly. you will find this is a lot easier.
Old 03-04-2011 | 05:45 PM
Uncle G.'s Avatar
Uncle G.
I cut a 3/8 long piece of a 1/4 inch allen wrench. I use a pair of tweezers to place the "little" wrench into the screw head, then tighten the assembly with a 1/4 inch open end wrench.
It sounds screwy, but it works.
Old 03-05-2011 | 10:01 AM
Idaho Scootertrash's Avatar
Idaho Scootertrash
I've done both methods as outlined by BL and Uncle G.
Either will work.
Old 03-05-2011 | 02:34 PM
tc's Avatar
tc
Default Smokey.
Thanks for help people.
Fitted carb to-day using Bikerlaw's stubby allen key idea and just took my time. Seems to have worked ok as there seems to be no leaks.
Bike runs and ticks over great, but, (always a damn 'but'), while ticking over she seems to be very smoky, about same from both exhausts, but when running is ok.
Would this be "normal" until things bed in, or.........(I hate to think).
Tony
Old 03-07-2011 | 08:30 AM
pjb's Avatar
pjb
what is "ticking over"?
Old 03-07-2011 | 11:18 AM
miacycles's Avatar
miacycles
Conteniental speak for turning over with the starter.
Old 03-07-2011 | 01:12 PM
BungoBill's Avatar
BungoBill
Hi Mia,not sure if thats what "ticking over" means in Europe but in the UK it means engine running without revving ie.....after starting,once engine is heated/warmed to its normal operating temperature,the engine is running (without choke),or use of throttle. we say "ticking over".
Cheers,Bungo.
Old 03-07-2011 | 01:46 PM
miacycles's Avatar
miacycles
You worder it better than I did. You actually said what I meant. I've heard lots of you guys use the term when they started their bikes and they were setting there. Thanks for the correction.
Quick Reply: Carb fitting.
