Carb fitting.
Old 03-07-2011 | 07:28 PM
#1rocketman's Avatar
#1rocketman
I thought the U.K. was in Europe?
Old 03-08-2011 | 01:17 PM
BungoBill's Avatar
BungoBill
Cool
Yes,the UK is in Europe,unfortunately for us at times!
The UK is not normally considered Continental unless perhaps by you guys in the US of A. Although some parts of Europe may be called "Continental" by us in the UK. Confused?? So am I.! Get Mr Graham Brown onto this. Im sure he will make things clearer than I can as he has done quite a bit of biking on the "Continent". What have I started??? Bungo
Old 03-08-2011 | 08:14 PM
capnfred's Avatar
capnfred
I found that if I mount the carb and back plate and get it all aligned, then tighten the two real bolts to hold the manifold in place, then remove the carb tighten every thing to specs.. then when the carb and backing plate are back on everything fits fine...the cut off allens work great in other places.. especially the Rocker box covers ....lots cheaper than the special tool.
PHAT A$$
11-08-2018 10:43 AM
Nasty514
06-24-2018 01:43 PM
ckary
Carburetor Related
04-23-2017 11:48 AM
pointdogg48
Shovelhead
10-08-2012 07:16 PM
rmarion
Classic
09-09-2006 01:58 AM
Quick Reply: Carb fitting.
