Thanks Guys found the starter problem
Pulled everything in the starting system mechanical. First the solenoid and found the rubber boot was busted where it seals to the primary housing, thus sol. was in too far. Then I pulled the starter all ok there. Rolled the starter/jackshaft gear all ok there. Pulled clutch basket (ring gear eat up) and then the jackshaft/starter clutch. Took all components off shaft and the spacer noticed spacer would not allow the clutch to move much. So I took spacer to HD shop in Danville and had Mech. look it over (along with jackshaft) he measured the spacer (looked homemade was made from copper tubing?) and it was 13/16" the OEM one in the book is 7/16" so the starter clutch could not return when engine started and solenoid disengaged and eat the ring gear up. Now I have ordered a rubber boot and spacer. and will put it back together. The PO must have done some work and lost the spacer and just cut a piece using the guesstamation technique and run it like that.
If he was gonna rig up something it looks like he would have at least used metal. Not a smart move.
