Stumped!!
Old 02-17-2011 | 10:56 AM
Edster 69's Avatar
Edster 69
Default Stumped!!
I have a 97 Roadking and the last few times I've changed the oil there has been hardly any oil when I pull the plug. There are no oil leaks on my garage floor there is bit of oil on my rear cylinder from the usual blow by from my breather (not much, more sweat than anything). I'm trying to trouble shoot but I'm stumped any input would be appreciated.
Thanks in advance,
Edwin
Old 02-17-2011 | 11:45 AM
NutterFLH's Avatar
NutterFLH
Next step would be checking compression in the cylinders.
Old 02-17-2011 | 06:27 PM
Havoc88's Avatar
Havoc88
I was loosing about a quart every 400-500 miles, turned out my '96 had a bady ruptured/torn valve stem seal. but it never fouled a plug and ran great, rebuilt it this year
Old 02-17-2011 | 07:17 PM
1bd99stc's Avatar
1bd99stc
Pull the plugs and look at them to see if there is any build up on them from oil, if there is build up on just one side most likely you have a valve issue, if there is build up all the way around the plug then most likely it is rings. If you have a valve seal that is bad there is a chance you can change them without pulling the head but its tricky. Hope that helps.
Old 02-17-2011 | 07:39 PM
sqdealgeorge's Avatar
sqdealgeorge
How's the prim oil level ?
Old 02-18-2011 | 12:21 AM
96 Wide Glide's Avatar
96 Wide Glide
Thanks in advance,
Edwin
You sure it's your engine oil drain your opening ?
Old 02-18-2011 | 07:43 AM
miacycles's Avatar
miacycles
How much oil on the stick?? Does it show low???
Old 02-18-2011 | 06:29 PM
#1rocketman's Avatar
#1rocketman
DITTO on the last 2 replys!
Old 02-18-2011 | 07:41 PM
Edster 69's Avatar
Edster 69
Oil stick level has been fine. Have just over 30 000 kms on her and primary oil is fine too. Valve seal sounds good for trouble shoot so I will have to look into it. Thanks guys,appreciate the input.
Old 02-18-2011 | 07:51 PM
96roadking's Avatar
96roadking
Is the oil stick level fine before you drain it? How about after you drain it? I'm a bit confused here.
