rebuild
Old 01-27-2011, 08:28 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,866 Likes on 2,429 Posts
Wink
Originally Posted by clove07
can anyone tell me what wiseco kit to use and what brand and size valves i need and what brand and kind of cam to use. And do i need new push rods, tappets and rockers etc.
To install a set of pistons you need to get your cylinders rebored to match them, something best done by a Harley specialist. If you don't have a local engine shop that can do that sort of work well, you have a volunteer here who can answer all your questions and supply everything you need! Give him a call. Don't expect professionals to tell all their secrets on a public forum!
Old 01-27-2011, 07:46 PM
mudbone13's Avatar
mudbone13
mudbone13 is offline
I read HD forums about every day, but I never post, so here goes. Scott is the MAN! Hillside rebuilt my engine and bottom end (along with other upgrades)last winter and kicked butt! Ended up with 90/90 and have loved it ever since. I put 16,000 miles on this year and the bike (Heritage Classic 1999) runs great. I couldn't be happier, in fact I haven't even told Scott how happy I am yet, but I have been planning on it. In fact, he still owes me a T-shirt which I will go back and claim someday. C'mon back to Batavia any time Scott.
Old 01-27-2011, 10:18 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
[quote=98 FLHX;7834133]
Originally Posted by 1997bagger
...without a doubt, Scott knows what he's talking about....
Yep-- in 2006 Scott at Hillside did a "longevity build" kit for me on the FLSTN when I was living in Singapore with his headwork at about 9.7/1 comp; Kibblwhite oversize valves w/3 angles, 30 thou cometic head gaskets and a Woods W6 cam; and I bolted on a S&S 'E' with a blended/matched intake manifold, a DTT ignition and a pair of Kromewerks HP+ slip ons with the OEM header pipes and OEM flat top pistons.
Every Sunday we would cross the border into Malaysia with 6-12 bikes and on a highway to nowhere I could run away from the 88" twinkies at the time.
When they caught up they would scratch thir heads and wonder how I could do that.
Still very happy with the build. Never put it on a dyno but conservatively estimate 80-85 HP and TQ, maybe a bit more.
Old 01-28-2011, 01:13 AM
Havoc88's Avatar
Havoc88
Havoc88 is offline
Just finishing a rebuild of my '96 FXSTSB, front to rear, I started to just do a mild top end, but well I like to go at least to some extremes. After a trip from central Washington to Reno NV, over to Eureka CA, and back home I found my stock 80" motor was drinking about a quart of oil in 500 miles. The valve guide stem seal was torn, Instead of doing the port-flow thing I bought a set of screamin eagle heads from Manchester Harley for 749.00 and sold my heads on e-bay for 250.00 so the cost was a wash with a port and flow, went with KB pistons and took compression to 9.5:1 I hate knock. S&S roller Rockers, pushrods, and tappets. Replaced the wheel and neck Bearings for good measure then had to replace the primary chain and drive belt (bike has 50k on it). As stated above I don't want to do so much to the top end that I grenade the bottom. Running a Spyke AIS ignition and an Andrews EV-23 Cam I found I had no problem keeping up with the twin cam boys, and I was getting better MPG's on long trips. What I wanted was my reliability with enough power to get out of its own way or pass a semi on a hill with all my crap and old lady on board. We'll see how it all turns out in the weeks and months ahead. Hopefully another 50k before I have to do the bottom end and freshen the top!!!
Hope it helps, oh, I run an S&S Super "E" along with a black thunderheader.
Old 01-30-2011, 08:39 PM
clove07's Avatar
clove07
clove07 is offline
im buying a set of screaming eagle heads and can anyone suggest a cam im trying for the 90 hrsp and 90 ftlb of torque and 10 : 1 pistons not sure what cam to use.
Old 01-30-2011, 11:41 PM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,788 Likes on 891 Posts
Not trying to be a smarta$$ but your SE heads will need the ports cleaned up to get 90/90 with 10-1 80". The SE heads that have been on the market for awhile have .575 spring lift travel so you are also limited to cam selection because the heavy hitter cams start in the .585 lift.
I am not discrediting SE heads, I had a set and good for what they are intended for but when purchasing new for $650-$700 and another $300-$400 to get another level HP and accept a bigger cam, I don't think they are good dollar per HP money spent.
The origional question on what cam to use with those heads in stock form, the V-Thunder 3030 would be a good one. Keep in mind that everything must work together and it takes knowledge of people like Hillside and John Sachs to not guess. Boy, do I know John schooled me on stubborness, it's sometimes best to look dumb and listen, usually it is also cheaper in the long run.
Old 01-31-2011, 09:34 AM
clove07's Avatar
clove07
clove07 is offline
The heads are at a local shop here were i buy some parts from. They are a customer he pulled off a motor they are in good shape and he said they are set up to were I can run pretty much any cam i wanted without any worry, but then again thats why im on this forum trying to figure out the best thing to do without going broke. They want $500 for the screaming eagle heads with all the valves already set up.
Old 01-31-2011, 12:52 PM
96roadking's Avatar
96roadking
96roadking is offline
I don't know how he could know what cams would work without knowing the CR, but otheres here, who know more could speak to that better than me. The other question that needs answering is, why were they pulled off of the other customers' engine?
Tony_N
EVO
17
02-01-2016 06:08 AM
fido1
Engine Mechanical Topics
03-26-2014 05:30 AM
eds06roadglide
11-14-2010 01:28 AM
Coxbow
Exhaust System Topics
04-25-2010 03:59 PM
QS78
06-16-2009 03:32 AM
Quick Reply: rebuild
