93 evo fatboy ticking noise?
Old 01-20-2011, 09:42 AM
ladman0311's Avatar
ladman0311
ladman0311 is offline
Default 93 evo fatboy ticking noise?
my 93 fatboy evo has about 25k on it. i keep the engine maintained regularley. i have noticed that when the bike is running i can hear a loud ticking and taping noise when im siting on it. im not sure what it could be. i think that it might be lifters or maybe the pushrods are out of adjustment but im not sure. Anyone ever have this problem? i know it is not due to loss of oil, i thought it was at first but eliminated that being the problem. i had recentley put in a single fire ignition system, but it was making the noise before i even put that in.
Old 01-20-2011, 10:50 AM
big cahuna's Avatar
big cahuna
big cahuna is offline
First, I assume you have the proper amount of oil in it. Second, if its all stock, the pushrods aren't adjustable. Third, I had a lifter wheel come apart on my '93 ultra a few years back. That's a big repair if it happens. I would be looking at changing lifters if I were you. But then again it could just be something loose on the bike. Go over it front to back with some wrenches Check the easy stuff first.,,
Old 01-20-2011, 11:35 AM
miacycles's Avatar
miacycles
miacycles is offline
Check the inner cam bearing and lifters, sooner than later.
Old 01-23-2011, 10:27 AM
hatchetman's Avatar
hatchetman
hatchetman is offline
Could even be a broken valve spring. Does the noise follow the rpm's or stay the same. How does the engine perform through the rpm band?
Hatch
Old 01-23-2011, 11:46 AM
96roadking's Avatar
96roadking
96roadking is offline
A stethoscope can be useful for narrowing it down, or even a screwdriver held to your ear and different parts of the engine. I have a ticking noise that I traced to the headlight nacelle, It's annoying but at least it's not the motor!
Old 01-23-2011, 12:00 PM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
Sounds like a bad lifter roller Mine was the rear intake caught it just in time The roller of the lifter was rotating up and down (not concentric) none of the needle bearings fell out Thankyou ! Replaced them all with HD newer B lifters
Old 01-24-2011, 06:31 AM
ladman0311's Avatar
ladman0311
Hatch
it seems to stay the same if i recall. im going to do a top end rebuild to it just to make sure. it is about due for one anyway.
Cohiba_Joe
10-26-2020 08:17 PM
rabid rider
11-21-2012 09:46 AM
kennyg104
EVO
69
08-16-2012 04:40 PM
ladman0311
EVO
21
07-12-2011 10:08 AM
jman92627
Exhaust System Topics
06-22-2008 11:23 AM
Quick Reply: 93 evo fatboy ticking noise?
