Evo Road king rear brake improvements
1 Post
Hi guys, came into a few hundred quid at the weekend after selling one of my pedal bikes and want to throw it at my rear brake, dont think i have enough for a complete caliper but was wondering what else i can do to improve it, currently running the original cast iron disc and stock caliper with stock hose.
front hoses are braided but rear never was so thats the first thing on the list. Would a disc upgrade make a difference? and lastly a new set of quality pads, anything else i could do any suggestions etc? dont want to go down the route of a newer swingarm etc so that i can getter a better stock calliper, i think i can get a Harrison Billet caliper for around £400 so if no major improvements can be had then i may just wait another month tilll i can afford the new caliper.
If you have enough rear brake to lock up the wheel, there is nothing you can do to the system to improve the braking except put a stickier tire on. I seriously doubt you're having heat soak issues, which would be the only other reason to change up the system. Now, if you just want bling-bling, that's different.
Buy a rear disc with the holes drilled in it. They allow for water between the brake pad & disc to escape giving you better braking in wet weather.
Replace your flex line because they do stretch out when old. for best braking, steel line will not give like flex line does. You will need a small section of flex for the swing arm movement.
Hatch.
Hatch.
1 Post
Thanks for the responses so far, at the moment the back wheel wont lock no matter how hard i push it, hence the want for improvement, the front brakes are on the list to improve as well but they work "ok" for now so will last another year before they get work done! I am after functional more than bling, especially as its behind a saddle bag anyway!
I have ordered a new disc (grooved and drilled) and pads and a braided line so will be fitting all of these this coming weekend along with a new rear tyre. Looking at the disc and pads when i pulled them last night both are very glazed up, the previous owner of the bike had it from new and only covered about 1000 miles a year (15 year old bike!) so things look new but have tended not to be, the dunlop thats fitted looks like new but is as hard as a rock, hence new tyre!
1 Post
Oh Yes mate, only way to go, going with a black wall on the back to save cleaning the bloody thing!
When i got the bike September last year it had 5+ year old dunflops front and rear, was awfull. front had to be done straight away as it was uneven and pretty much on the limit, the back still looks like new but is rock hard.
Should make the thing handle even better, was good after the touring link was added late last year and the bike aligned, should be even better now!
