First fill-up now leaking at carb
Old 01-10-2011 | 03:50 PM
Headcockedsideways's Avatar
Headcockedsideways
Originally Posted by miacycles
Float/needle/seat is usually the culprit, however a plugged tank vent can also cause that problem, especially with a full tank.
Yeah...the 'full tank' thing is what alarmed me at first. The bike was registering a half tank when I got it and I haven't got to ride it much. I was keeping a real close watch on it for leaks. I know it hadn't leaked in almost 3 weeks, ever since I got it. When I saw it leaking right after I filled it up I first thought it had a high tank leak but as I traced it down, it was coming from the carb.
I'll hafta get my service manual out and pull the needle float out of it and check it out.
I can't get to it today. Got about a foot of snow on the ground and I can't get to my shop where I keep the bike.
Old 01-10-2011 | 03:54 PM
96roadking's Avatar
96roadking
I think what John was saying is that a plugged tank vent could force it out the carb.
Old 01-10-2011 | 05:53 PM
miacycles's Avatar
miacycles
Exactly, the difference in "head pressure" between a full tank or less is minimal. When the tank is full there is less air space to compress, so it forces the needle open. Park the bike with the cap loose and see if it still does it.
Old 01-10-2011 | 06:22 PM
Jim Kraft's Avatar
Jim Kraft
I would think the auto shut off on the fuel tank valve would keep the pressure from getting to the carb. You could try shutting off the fuel valve at the tank, and see if that stops it. I am guessing, but it probably has a little crud under the needle as said above. It is pretty easy to clean. I can take the bowl off of mine without removing the carb.
Old 05-30-2011 | 11:47 AM
Headcockedsideways
Just wanted to update this discussion and let you guys know that this has never happened again.
Thx to all who jumped in to help me out!
Jeff
Bsanchez13
05-25-2018 08:37 PM
randybecker
09-14-2011 11:29 PM
JohnFlorida
Exhaust System Topics
04-26-2011 02:33 PM
rivercityslim
EVO
11-07-2007 10:51 AM
Quick Reply: First fill-up now leaking at carb
