shifter shaft bushings
Old 01-04-2011, 05:35 PM
bdm1960's Avatar
bdm1960
bdm1960 is offline
Default shifter shaft bushings
how hard is it to change the shifter shaft bushings
Old 01-04-2011, 05:44 PM
flyingtiger77's Avatar
flyingtiger77
flyingtiger77 is offline
Easy, I took mine out to have it powder coated. Just turned down a piece of round bar on the lathe to match the ID and used a mallet to push out. I know not everyone has access to a lathe, so you could find a dowel or tool with the same ID.
Old 01-04-2011, 09:38 PM
RidemyEVO's Avatar
RidemyEVO
RidemyEVO is offline
I will be doing mine this winter and I think a socket and nut and bolt through the whole will pull it through or just thinking out loud what about using a new bushing with a nut and bolt , tighten up the nut and bolt and at the same time pulling the new pushing through , probably need a bigger socket for the old bushing to go into.
Old 01-04-2011, 10:17 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,911 Likes on 1,426 Posts
I struggled with that thing for a long time. I never could get the old one out. Finally, when I had the primary off, I managed to drive it out. Then I made a new bushing out of Delrin (on my lathe) and it has been great since. Much nicer, tighter, smoother than the stock one ever was.
SpringerSoftail2020 (06-27-2024)
Old 01-04-2011, 10:26 PM
RidemyEVO's Avatar
RidemyEVO
True Dr H , I'll be replacing the 32 amp charging system with a 38 and while inner pri is off I'll install a new bushing.
Old 01-05-2011, 09:12 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Talking
I like the idea that a lathe is essential back-up for an Evo....
iamcmf99 (11-28-2019)
Old 01-05-2011, 09:18 AM
RidemyEVO's Avatar
RidemyEVO
Hey its an Evo so anything is possible.
Old 04-04-2011, 08:42 PM
mtnlvr's Avatar
mtnlvr
mtnlvr is offline
So I'm looking to replace my shifter shaft bushing this week or next. Anything else I should be looking to replace / inspect while I'm in there? Just got a new stator within the last 2 years, and a new belt / pulleys a year before that. I may consider an M6 or Hayden chain tensioner if there's no reason not to.
Old 04-05-2011, 04:46 AM
RidemyEVO's Avatar
RidemyEVO
Make sure you do a measurement on the shifter shaft itself against the new bushings, when I did mine I found there was still alot of slop and I suspect its because the shaft itself is worn.
Old 04-05-2011, 05:22 AM
grbrown's Avatar
grbrown
grbrown is offline
I agree. It would be a bit like fitting new plain bearing shells on a worn crankshaft. I suggest renewing all the mating parts, ie bushings and shaft.
Quick Reply: shifter shaft bushings
