shifter shaft bushings
Old 11-04-2019, 06:11 PM
UrbanMaster555's Avatar
UrbanMaster555
UrbanMaster555 is offline
3rd Gear
I didn't counter-sink them actually. I got it flash against the shifter housing with my washers. Both the housing and the bushings seemed to be machined to allow for the o-rings. I used these bushings: https://www.ebay.com/itm/Shift-Lever...72.m2749.l2649
Here is the bushing replacement tool:
https://www.denniskirk.com/jims/shif...prd/284319.sku
From the pictures it doesn't look like the installers have a lip for sinking the bushings.
I guess if you wanted to, you could put a socket on the bolt instead of one of the washers and sink the bushings one at a time. I wouldn't tap it in with a socket.
Thanks for pointing this out!
Old 11-04-2019, 09:21 PM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is online now
Received 1,655 Likes on 1,128 Posts
The Jims tool (#5518) was designed for the touring bikes (FLH, FLT) and on those bikes, you do not need to countersink the bushing for an o-ring, since on those bikes, you don't have an o-ring. On my softail, the OEM o-rings were countersunk. When I replaced my bushings, I countersunk them. Unfortunately, my factory service manual doesn't have any information on changing these bushings. I just happen to notice how the original ones were installed and duplicated it.
Old 11-05-2019, 08:08 PM
UrbanMaster555
3rd Gear
I'll do some research, maybe swing by the dealer and if i'll end-up making adjustments I'll make a follow-up video and post it here.
Old 11-22-2019, 03:28 PM
UrbanMaster555
3rd Gear
I couldn't resist countersinking the bushings and made another related video. Check it out:
Old 11-22-2019, 06:34 PM
LQQK_OUT's Avatar
LQQK_OUT
Good job!
Old 11-26-2019, 05:27 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 7,209 Likes on 2,886 Posts
I changed the bushings on my 93 Heritage a couple of days ago. I didn't have any of the specialty tools so I drove out the old bushings with a socket then got the new bushings started and slowly pressed them both in at the same time with my vise. Out again, in again Finnegan. Piece of cake.
Old 12-03-2019, 04:54 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Originally Posted by grbrown
I like the idea that a lathe is essential back-up for an Evo....
Nah, not really. I never had a lathe and although this '93 is my first Evo everything else for the last almost 50 years has been Shovels and Pans. Then again you can't be that deep in it without having made the acquaintance of 5 or 6 people who do own one!
grbrown (12-04-2019)
Old 06-21-2024, 12:40 AM
ffron6969's Avatar
ffron6969
ffron6969 is offline
thank you for doing this!!
Old-Evo
EVO
25
06-04-2024 03:31 PM
cajun1957a
08-10-2018 04:26 AM
benson1603
2014-2023 Touring Models
07-22-2014 08:06 PM
BK-DE1
12-05-2013 09:35 PM
speedkills
03-02-2010 08:20 PM
Quick Reply: shifter shaft bushings
