Turn the gas off?
Old 12-16-2010 | 10:11 PM
TurkeyRun's Avatar
TurkeyRun
Default Turn the gas off?
I went out to put a battery tender on my "new-to-me" '96 FLHR. When I was out in the garage, I noticed that I didn't turn the fuel petcock off when I parked last. Now, in my old metric-bike days, leaving the petcock open and parking a bike for more than a few minutes meant fuel all over the bike, floor, everything. To my (pleasant) surprise, the RK was dry as a bone!
After making sure the battery was healthy, I fired her up, seeming no worse for having the fuel left on. Granted, it took a bit as it is in the low 30's out here.
So, my question to the group is, do I really need to worry about turning the fuel off all the time?
Thx
Old 12-16-2010 | 10:35 PM
grandparon45's Avatar
grandparon45
Yep, to be safe, turn the gas off. Also it is a good idea to add Stabil gas additive and fill the tank completely full for the winter to prevent corrosion in the tank.
Old 12-16-2010 | 11:17 PM
woodnbow's Avatar
woodnbow
I do. Just an old habit, I'm told the newer bikes with vacuum controlled petcocks don't require it but it's a mechanical device and they do fail. The worst part of the failure is not the gasoline all over the floor routine, although that's a pain and slightly dangerous to boot. The worst part is the gasoline that runs through the carb into one or both cylinders, washing away the oil and making for a nasty dry start. Once you get in the habit of doing it every time it's really no big deal... If you buy a pingel or similar aftermarket petcock it's even easier.
Old 12-16-2010 | 11:29 PM
Scratt's Avatar
Scratt
Turn it off, and if your going to let it sit for a while run the fuel out of the carb.
Old 12-17-2010 | 02:15 AM
RidemyEVO's Avatar
RidemyEVO
I never turn the gas over even over the long winter months.
Old 12-17-2010 | 06:44 AM
miacycles's Avatar
miacycles
Older bikes had a brass needle and seat that would leak evenyually if you did not shut them off. The newer carbs have a rubber Viton needle that pretty much cured that. Can fuel get by if it isn't working properly??? Certainly, so it actually comes down to your preference if you have a modern carb.
Old 12-17-2010 | 08:27 AM
hotrod351's Avatar
hotrod351
well seeing as its gravity feed the only thing that could happen is to fill the engine up with gas and, or, dump gas all over the place.
Old 12-17-2010 | 09:49 AM
bikerlaw's Avatar
bikerlaw
I thought the '96 had an automatic vacuum shut off. In fact my '96 never leaked a drop of gas....ever.....till I installed a Pingle Petcock and removed the stock vacuum unit. Once I put the Pingle on I had to adjust the dang float.
Old 12-17-2010 | 02:15 PM
Calwoodbutcher's Avatar
Calwoodbutcher
I always turn it off. How much effort does it take? Of course my bikes are all a little (or a lot) older.
Old 12-17-2010 | 02:22 PM
Len's Avatar
Len
YEAH, turn it off . .
Quick Reply: Turn the gas off?
