winter rejet?
winter rejet?
i decided to take the bike out yesterday, it was about 45 deg. outside. i noticed the bike acted much leaner even after a 20-30min ride on the highway and back roads, even got a couple of carb farts cruising at 60 mph. the bike has always ran smooth during the warmer temps is this the norm or do i need to adj. the carb?
carb has 45/180 jets 1.5 turns out on mixture plug, bike is stock sept for slipons.
what do you think?
what do you think?
what do you think?
what do you think?
If your slide vacuum port is drilled it could be giving you a drivability problem from the slide opening too fast and causing a momentary lean condition which would result in a pop back.
funny thing is that the bike came with a 185 main, which i thought was too rich.
it would just smell rich and it would start up with no choke, now it seems like maybe the p.o. had a reason for the 185 main jet. the original plugs were a nice chocolate color so now im thinking it was a mistake to goto a 180 main.
Run the bike through the gears into third gear and run third up to 60-70 MPH full throttle, then chop the throttle about 1/8 to 1/4 back and see if the bike either surges ahead or stumbles then recovers.
If it surges ahead, your jetting is lean.
If it stumbles and recovers , your jetting is rich.
If it makes no difference, you're pretty close
It should tell you something about the main jet size.
