Need help buffing out swirls.....
Mcguires makes a foam pad for a buffer and a product made by 3M called Finesse(white) works good on removing swirls on black. The key is low speed with the buffer and just tapping the trigger to keep the wheel moving slow works good on the final buffing and don't use the edge of the wheel, try to keep as much pad on the surface as possible. Go back over it with the Finesse by hand to finish off any imperfections left from the foam pad.
Mcguires #7 puts the rich color back into black paint and brings the deep gloss back out, it's not a wipe on and wipe off product and takes some work but clearly the deepest shine when done.
You can also try your swirl remover with the pad, just try the slow speed method but the #7 is unbeleivable with black after all of buffing is done, put the #7 on by hand.
Eastwood sells a product called liquid ice...uses progressively finer pads rather than compounds to produce a killer finish. Most amateur friendly system I have used.
http://www.eastwood.com/6-inch-compl...ingsystem.html
Depends on how bad/condition the swirls are in. I've used a random orbital polisher (Porter-Cable) on my black car. Took me 3x to make it shine and each time it was these steps:
* Wash
* Clay bar
* Wash again
* Polish
* Polish - Finer
* Wax
Total time for my car to bring back the shine was 27 hours (10, 9, and 8 hours). After the third time, my car had the "20 foot" look - after rain, from 20 feet, it still looked good. All what you want the paint to look like.
* Wash
* Clay bar
* Wash again
* Polish
* Polish - Finer
* Wax
If you are not comfortable with a buffer, use the 3M Imperial hand glaze as the guys mentioned, trying to use a abrasive buffing compound by hand usually turns out doing more damage than good. First step: Get the paint clean with the Imperial, Second step: Mcguires #7 is great for black if the paint is clean and then, Third step: put a wax on last as a protectant.
You can skip the #7 on the second step and Eagle One makes a good wax that also puts the richness back in black if you want to save some jingle and step, depends on how picky you are, I showed a large black 4x4 for 8 years and used the #7 before every show, so I have rubbed on black more than I cared to
