Why Dynas use longer oil filter?
Dealership recommended to use filter #63805-80A for my Dyna. It should be good because it's 30 micron size filter which is good for Evo engine. My manual says about filter #63812-90 (longer size) and it's dedicated for Dynas. Right now I'm using #63805-80A and start to hear some knocking sound from engine. Could it be related?
I copied these descriptions from a Harley dealer's website:
( Part No: 63805-80A )
Black, Long.'Fits late ’82-’84 FLH-80 Classics, ’82-’86 FXWG, FXSB, FXEF, ’79-early ’84 XL models.''Fits ’80-’98 FLT, FLHT, FLHR, ’82-’94 FXR, ’84-’98 Softails, ’84-’95 FXRP, FLHTP, late ’84-later XL and ’08-later XR models.
( Part No: 63812-90 )
Black, Extra Long.'Fits late ’82-’84 FLH-80 Classics, ’82-’86 FXWG, FXSB, FXEF, ’79-early ’84 XL models.''Fits ’80-’98 FLT, FLHT, FLHR, ’82-’94 FXR, ’84-’98 Softails, ’84-’95 FXRP, FLHTP, late ’84-later XL and ’08-later XR.
Apart from length they seem to be identical, so there should be no link between them and your noise. Prompts me to take a look at the difference when I am next at my dealers!
Just a guess but they use a longer filter because there's room for it. More filtration is better. Along those lines, I've been using twin cam filters for a few years. Read about it in American Iron I think and so far so good, apparently the twinkie filter has significantly higher level of filtration.
I understand twincams do use a finer grade of filter. I have had an S&S motor fitted in my Evo and it was made very clear to me I should not use TC filters! Not sure why, except for some reason they are not suitable.
Dontcha just love the straight scoop you can get on internet boards?
I've always heard the long filter called 'dyna filter' at the dealership and elsewhere even if the description doesn't. I've used them on Dyna's, tried to use them on FL's and couldn't because they were too long to fit.
I'd agree, the knocking noise is not likely to be related to the filter, I'd look elsewhere.
There are two issues here. AlgorNick asked about two filters, one of which he describes as a Dyna filter. That is not supported by the descriptions I posted, the two numbers apparently being different in length only. However the longer one is recommended for early Dynas I have now found. It may be they have a longer service interval between oil changes?
TwinCam filter #63798-99A is not suitable with EVO engine. I think because it's 5 microns filtration.
Here is info about it: http://www.hdtalking.com/oil_related....html#post3909
The long filter will work on any EVO that it will physically fit on. The twin cam filter has a by-pass valve that takes more pressure tto open it if the filter is clogged that the average EVO can generate normally. This would lead to a disasterous end to your engine, as they do not normally like to run very long with out oil flow.This is also a problem with some of the car filters that peope get from advance auto, etc. Just because it screws on and oil goes through it doesn't mean that it is the proper filter. Hope this helps.
John, thanks for that!
Interval is 5K miles on Dynas. It looks like the size is only difference. It's good to hear.
