Why Dynas use longer oil filter?
Old 11-10-2010 | 06:31 PM
IronGear's Avatar
IronGear
The longer filter was introduced for dynas, as the relocated sump provided a smaller oil carrying capacity. It has nothing to do with filtration.
Of course you could use the same long series on any evo that it can physically fit onto.
Oiling systems and filters need to be matched.
Installing a 5 micron filter onto an engine that has a pump designed to be matched with a 35 micron filter is clearly a bad idea. A key element here is that the 5 micron filter is intended for systems that filter on the feed side, not the return.
The by-pass filter has nothing to do with it.
Naturally, it has to have a higher release point, as it is on the feed side, and it would be open all the time otherwise. But that does not make it the reason why you should not run that filter on an evo. Far from it. That is merely a side dynamic. The primary concern is the matching of oil pump pressure and flow characteristics to the filtration medium.
This is obvious, as in a correctly functioning system, the bypass valve is never called upon, WHEREAS THE FILTRATION MEDIUM IS OPERATING CONSTANTLY.
Old 11-10-2010 | 07:15 PM
darylnj's Avatar
darylnj
Default filter
why dynas use long filters
because they can
the part number for our filter is 63813-90
been buying them for 16 years
Old 11-13-2010 | 01:14 AM
chuckw2's Avatar
chuckw2
dealer parts guy told me the long filter was used to help keep the stator plug in place.
Old 11-13-2010 | 02:45 AM
IronGear's Avatar
IronGear
If you are serious, and he was as well, shop elsewhere.
Old 11-13-2010 | 10:18 AM
chuckw2's Avatar
chuckw2
I am serious. That's what he said when they were out of the long filter and I asked about the short one. Seems reasonable to me since there is no clip or anything to keep it in place and the filter pushes on it slightly.
Old 11-13-2010 | 11:31 AM
Jim Kraft's Avatar
Jim Kraft
It is confusing. My 99 EVO manual calls for the high filtration filter, the same one listed for the twin cams. And, HD recomends that same filter for the older ones as an upgrade. I am now using the old style low filtration filter on mine. I have used the high filtration filter without problems, but after reading all the info here, I will continue to use the low filtration filter. I change oil at about 2,500 miles on average anyway.
Old 11-13-2010 | 08:59 PM
eightballdave's Avatar
eightballdave
Default For what it's worth...
I've got a fatboy, so the filter is out in front of motor. I run the short filter in the cooler months, and the long filter in the summer, as I think it helps cool the oil.
Old 11-14-2010 | 06:18 AM
grbrown's Avatar
grbrown
Question
That IS confusing! Perhaps Harley upgraded the later Evos to a similar spec oil system to the TC one? They made both engines at the same time for a while. I wonder if there is a way you can confirm that, such as at a local dealer, with your VIN?
Old 11-14-2010 | 09:11 AM
miacycles's Avatar
miacycles
No the oiling system is the same. Put twinky filters on twinkies, evo filters on evo's and be wary of auto filters!!!!!!!
Old 11-14-2010 | 10:03 AM
98glider's Avatar
98glider
I have a 98 superglide I tell them the year and they give me the short one and I tell them the long one. I just thought the new ones and the old ones were the same The stealers probably are giving me any one Do you know the part number for the 98 Thanks
