S&S Super E pukeing fuel
The same happened to me a few months ago...The rubber tip on the float needle has a tendency to get brittle with the 10% ethanol gasoline...It also chews away at the accelerator pump diaphram...About every 3-years I'll be replacing the accelerator pump diaphram, float needle and seat, and all O-Rings that come in contact with the fuel.
As already mentioned, check your float level adjustment too!
Thanks for all the info. The gas cap DID seem to have a nice suction on it the last time I fueled up. I've yet to pull the bowl and check the float but it's gonna be the first step. I've owned the bike for three years and I have not rebuilt the carb yet. Maybe it'll be on the "to do" list.
CRAP! Today the speedo quit and the blinker cancel feature stopped working. I just replaced the speedo cable and gear drive not too long ago.
Anyone know if the blinker cancel feature is somehow tied into the speedo housing? I mean, the speedo itself is straight mechanical. At least it won't be a hard fix.
