no clearance
no clearance
I am trying to get my rear rocker cover off of my 97 fxds-conv. The rocker is smack against the frame, I have totally removed front engine mount and dropped engine, which only allows me 3/8" clearance of frame and I cannot get the top rocker cover off and clear of the lower hold down bolts. What the hell am I supposed to do? everybody tells me it shouldn't be a problem and I should have 1" of clearance, NOPE!!!!
The 2 threads on spark plug side are stripped and no longer hold the bolts, I want to remove lower rocker, drill and tap to 5/16-18. That's if I can get it off.
Thanks, Joe
Thanks, Joe
If i understand:
1-you removed front motor mount completely and dropped motor.
2-you probably also loosened and raised rear of tank up an inch so you could see.
3- do the rocker covers have female allen head holes?
if they do..go to sears and get the 10-pc MIDGET COMBINATION WRENCH SET
i think it is item number 9-42319 and is about $20..you really only need the 3/16 wrench?? it is small and thin..then cut a piece of allen (3/16 ?) and drop it in the allen bolt..use little wrench to turn the allen piece that was inserted in the bolt.
Original Rocker boxes are 3 piece..pop off the top one after removing the four bolts and remove...If original..the top rocker will feel slightly glued down..just pop it with-out bending..spatula?
**the sears wrenches are very small and they are the only ones i have seen that are that tiny and at the same time very strong..Most times they are out of the standard size ones..maybe 1 of 3 stores has them in stock.
AND just to be clear..sometimes you can not actually physically remove the bolts but instead must loosen completely and pop rocker to off and slide out with bolts just resting.
help this helps.
help this helps.
I can get the bolts out no problem, I have the top cover released but it doesn't have enough room to get past the bolt tops that are on the inside holding down the lower cover. I do get some vibration that gets annoying sometimes, and after seeing this , it might be the culprit. I will look at the exhaust mounts near bottom of bike and see if that's keeping it from dropping more. I bought this bike last yr used, so I don't know what is or isn't stock. I will try again tomorrow and take pics.
Joe
Joe
