Oil pressure...
Old 08-24-2010 | 11:17 AM
ultra97's Avatar
ultra97
Default Oil pressure...
Was wondering what kind of oil pressure everyone with a evo was getting...I know that the flow is more important...Myself hitting the interstate about 70 to 80 mph,psi may be 8 to 12 lbs.of psi @ 100 degrees...I'm sure its just the heat doing this...
Old 08-24-2010 | 11:33 AM
1987fxr's Avatar
1987fxr
at idle mines at 9 psi and anything over idle it shots up to 20 at highway speeds its at like 25 but it has s&s oil pump
Old 08-24-2010 | 07:23 PM
ultra97's Avatar
ultra97
Thanks,thinking its about to change the oil ,I'm sure it will help..Bout the same at idle as yours,but 70 to 75 it runs between 9 to 15 with stock oil pump..By the way all that helped with the burning up stator problem that I had it was the rotor...Got 500 miles on it no problem so far...Always something...
Old 08-24-2010 | 07:31 PM
miacycles's Avatar
miacycles
7-10 lbs. per 1,000 RPM"s is normal oil pressure for most EVO"s.
Old 08-24-2010 | 07:53 PM
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
May be the El Cheapo oil pressure gauge I have on Bertha, but it always reads around 15-20 at idle, and about 25-30 at higher RPMS. From what I've read, I guess that's OK.
Glad to hear you fixed your problem with burning up stators. What was the problem with the rotor?
Old 08-25-2010 | 10:59 AM
ultra97's Avatar
ultra97
It was the wrong rotor,Some said I could run a 45 amp rotor with a 38 amp stator,this coming from a bike shop...Didnt work for me,maybe some have been able to do it..
Old 08-27-2010 | 06:38 PM
Tactical111's Avatar
Tactical111
Thumbs up Congrats...
on getting that fixed. I was thinking that mismatched rotor would be a problem but someone else had already mentioned it. All I have on my '91 FLHS is oil "idiot" light that goes off after start up. Have 65k miles; new top end at about 48k and never had oil pressure issues. Oil tank cap does pop out and hang there occasionally only on start up so I have to remember to reach down and check it each time. After I'm up and running it never pops out.
Deaners1969
EVO
57
04-27-2018 08:17 PM
Lotaluck
06-29-2016 06:25 PM
DC COBRA
06-09-2014 11:04 AM
FL-kruzen
11-13-2012 04:50 PM
catcher
Oil Archive (no new posts)
12-16-2006 10:13 AM
Quick Reply: Oil pressure...
