what oil do you use
Old 08-02-2010, 12:58 PM
Hackd's Avatar
Hackd
Hackd is offline
^^^ X2.
I run dino HD oil in the engine, and Mobil 1 gear oil in the trans. Since HD stopped providing the dino oil for the primary I've been running their 'other crap'. I'm about to switch it to RedLine, ATF, or something else.
Old 08-02-2010, 12:59 PM
JohndeereA's Avatar
JohndeereA
JohndeereA is offline
Some companys make oils just for air cooled engines, such as Valvolene.
They have the 20-50 for auto use and the 20-50 with the "M" for motorcycle
and air cooled engines.
I was lead to believe only to use the "M" class oil in motorcycles because
of the different phosphorus/zinc content of the "M" oils.
Just a thought.
Old 08-02-2010, 02:48 PM
pajoe's Avatar
pajoe
pajoe is offline
Valvoline VR-1 20w50 (engine)
Castrol Type F ATF (primary, may try B&M Trick shift)
Harley Formula + (transmission)
On edit: from http://www.blackstone-labs.com/faq.php
What's the best oil to use?
Ah, the million dollar question. We are an independent lab, so we don't make recommendations. It has been our experience that oil is oil, and either petroleum or synthetic-based oil will work well for just about any engine.
Come on, you're holding out on me. I should use synthetic, right?
Buddy, you should use whatever you want. Synthetic oil won't guarantee a longer engine life any more than my eating organic food will guarantee I'll live until I'm 90. We here at Blackstone generally use regular petroleum-based oil because honestly, it works just as well for us.
Old 08-02-2010, 03:26 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I hate to open these threads since opinions vary so much, but I'm throwing caution to the wind and throwing my two cents in. Since much of the oil debates revolve around synthetic vs. Dino, I run semi-synthetic 20-50, that way who ever wins the debate when all is said and done, I'm on the winning side. I put Harley primary/transmission fluid in the primary and the same stuff mixed with Mobil1 gear lube in the tranny. No matter what you dump in, I think changing it more frequently than required does more to prolong your ride than anything else does.
Old 08-02-2010, 04:39 PM
96roadking's Avatar
96roadking
96roadking is offline
I use slippery, somewhat viscous, fluids in all 3 holes.
Old 08-02-2010, 04:47 PM
RidemyEVO's Avatar
RidemyEVO
RidemyEVO is offline
I just started using the harley screaming eagle synthetic in all 3 holes and funney thing happened for the past year I've had a problem with my clutch grabbing real hard in first gear starts if I gave too much throttle and released the clutch too quick and since using the screaming eagle I have 100 % improvement. As for the gearbox and engine I can't really say there is any differnce, the rockers still do there dance.
Old 08-02-2010, 05:01 PM
oppirs's Avatar
oppirs
oppirs is offline
Default Castrol GTX 20-50
Another vote for Castrol GTX 20-50 but I use the HM (high mileage) extra additives for my 24 y.o ride.
Old 08-04-2010, 05:08 PM
rossn2's Avatar
rossn2
rossn2 is offline
2008 RoadKing Classic:
Amsoil 20w-50 Engine and Primary
Amsoil 75w-110 Gear oil in Transmission
Old 08-06-2010, 12:34 PM
Kramer Krazy's Avatar
Kramer Krazy
Kramer Krazy is offline
Originally Posted by harvrk
what are my options?
For the first 40k or so I used Harley fluids and for the next 60k+ I have been using the absolute cheapest dinosaur 20w-40 oil I can get my hands on. Usually I wind up buying store-brand oil in the gallon container. My engine's bottom end has never been worked on and the top-end has only been done twice for leaking base gaskets. The bike has over 105k miles on it and I change the oil every 2000 miles with a new filter every-other oil change (every 4000 miles). My average oil change is about $10.
Old 08-06-2010, 12:39 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,250 Likes on 1,641 Posts
-M1 20W50 Synth in motor
-Spectro 6-speed GO in tranny
-Spectro Primary fluid
Works well in my 09 FLHX...
Quick Reply: what oil do you use
