Broken exhaust pipe support
OK, how might this have happened. I have a 96 FLSTC with duals (one pipe down each side). Went for a ride today and noticed a rattle/banging from under the bike. Look and find that heafty piece of chrome steel that keeps the aft end of the tail pipe steady is broken just forward of the forward bolt hole. Now that is one big piece of steel to have broken by work hardening. Is that possible? Anyone have any luck welding it together or do I need a whole new one. Not fussy about needing chrome under the bike.
Thanks in advance
John
Thanks in advance
John
I had the muffler support on my flst break about 15 years ago. But the bike is not duals. I kept hearing a loud click every now and then while riding...when cleaning the bike I found that the bar cracked in two...it was part 65459-84. I just ordered a new one instead of having it welded. This support bolts to the frame.
Broken muffler bracket
Well, I called the local Harley dealer, seems my description of the exhaust system appeared to be aftermarket and of unknown make did not register. After he looked up the part for a stock FLSTC, he seem at a loss as to why my description and the part he had was no where near the same as the part he had in his hand. After the third explaination he finally said, this must not be a stock exhaust. For $10 I had it welded.
CoyoteQuick
The General Motorcycle Forum
10-01-2011 06:22 AM
