cylinder stud blues
"I've Heard" on teh 1ntr4w3bz, y0, of people repairing that with Helicoils or Timeserts with a rag in there, shop vacuum cleaner running, grease on the tap, etc. That's what I would do if I found myself in that situation.
Timeserts are supposed to be stronger than Helicoils. Either is stronger than the base aluminum and original threads.
Keen-sert also make a repair that is identical to the Time-sert. To keep debris out of the cranckase go to your local Upohlstery shoh and have them cut two circles of three inch thick foam slightly larger than the spigot diameter and sit them down the middle just past the center. Then slide them over the rods and down into the spigot hole. They will seal the opening better than anything else you can use and the vacuum won't suck it out of the spigot hole. Next use the vacuum and some grease on the drill bit and tap. Be careful not to get the drill bit too hot as the grease will melt. Have a friend make sure you are going in straight and take your time.
I did order the time-serts today so I need some ideas on keeping any steel particles out of the bottom of the cases. I was thinking maybe filling the stud hole with grease before drilling.
Thanks John it kind of sounds like a good idea although I don't quite understand, any chance of describing your idea in laymans terms, I am very interested in any ideas for keeping and shavings out of the casings.
Thanks John that makes scence now, I think I actually have a rather large chunk of old car seat cushion that may do the job as well.
I ordered up the time-sert and it should be here Thursday, after talking to the tech at Time-fasteners he made it sound very easy, he suggested filling the two holes that I will be repairing with heavy grease to help stop any chips from falling through the bottom.
When I first found out the front stud wasn't tightening down and in turn the stud and threads were pulling out as I was torquing this may work the same for the rear cylinder if I put the jug and head back on and torque until it comes loose and out.
Ovens are for heating heads to remove studs and valve seats, transmission cases to install main bearings, engine cases to help remove pinion bushings. And automatic dishwashers are for cleaning transmission cases, engine cases and hand tools. And if anyone's wife has a problem with any of that, get a divorce - no need to be married to a female who doesn't know how to use shop tools
